Render stops saying system low on memory
Aaron Wiesen replied 16 years, 5 months ago 7 Members · 27 Replies
John Rofrano
March 30, 2010 at 10:57 amLooksBuilder is version 1.0.3
My LookBuilder says that it’s version 1.4 when I go to Help | About. My latest download file is MBL_Win_Full-1.3.zip and the installer inside it has a date of 2/9/2009. It looks like you may have missed an update or two.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Mike Kujbida
March 30, 2010 at 11:41 amThanks John.
It looks like an email to Red Giant support is in order as my LooksBuilder now says version 1.2, even after the 1.3 MBL update 🙁 -
Mike Kujbida
March 30, 2010 at 12:00 pmJohn, one more (potentially dumb) question.
You’re installing the Sony Vegas version and not the Stand Alone one, correct? -
Hallgeir Gjesdal
March 30, 2010 at 8:29 pmHi!
Had the same problem a while ago and been watching this thread for a possible workaround…
Yesterday I googled the subject and came across this tip.. I followed blink3times solution.
It’s all about entering properties of vegas90.exe and plugins in use and change advanced options (with CFF Explorer) to ‘App can handle >2gb address space.
I performed the actions and went for rendering, and it worked!! On a 32 bit Vista with a 32 bit Vegas!
It’s kind of advanced and you should ofcourse make a backup of file, and a restore-point before changing anything.
Read thru the thread carefully and dont do it if you’re not sure what you’re doin’…
Good Luck and Happy Rendering 🙂
John Rofrano
March 31, 2010 at 11:32 amYou’re installing the Sony Vegas version and not the Stand Alone one, correct?
Nope. I have the stand-alone version installed as well. When I invoke that it also says 1.4 so maybe that’s where Vegas is picking it up from.
~jr
Aaron Wiesen
April 6, 2010 at 6:04 amWindows 7
Sony Vegas 9.0c (32-bit)
Magic Bullet Looks for Sony Vegas (32-bit plug-in only, and the reason 64-bit Vegas was not being used)Hit this error dozens of times rendering out to every Avi and Quicktime format Vegas could throw out.
Stumbled on this CFF explorer solution and had a working render thirty minutes later.
“Thanks” doesn’t even begin to cover the headache you’ve saved me. Should I ever happen to meet you on the street somewhere, I owe you a drink. ^_^
