Activity Forums VEGAS Pro Render Speed settings
  • Render Speed settings
    Posted by Don Cobble on November 4, 2011 at 4:07 pm
    I cannot get my project to render more than 15 -18 % CPU usage. I left a 30 minute clip to render last night. 8 Hours later – this morning it said 19 hours left!!!!! Is there a piece of hardware I can buy???? A setting I can change??
    Tried both Vegas 10 and 11 same thing
    I am rendering out
    Cineform 1920×1080 30P
    with Newblue Effects Chromakey/soft focus and some Sony color correct
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Vegas 10 64bit & Vegas 11 64Bit & Adobe Production Premium CS5.5
    Camera
    Sony EX1 shoot in 1920×1080 30P
    Stephen Mann replied 14 years, 10 months ago 2 Members · 5 Replies
  • Stephen Mann
    November 4, 2011 at 7:05 pm
    CPU usage is a very poor indicator of system performance. All this tells you is that the CPU is not the bottleneck in your process. What format are you encoding and what F/X do you have on the timeline?
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Don Cobble
    November 4, 2011 at 7:22 pm
    I am encoding files to then re-enter the finished file back into a project – I tried stacking Veg files but it just is to much a load on the system. So I am trying to render out in a format that is a s lossless as possible for the final rendered project.
    I am encoding to Cineform 1920×1080 30P “High”
    New Blue – Soft Focus
    New Blue – Chromakey
    new Blue – Color Swap
    Sony – Color Correct (secondary)
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Camera
  • Stephen Mann
    November 4, 2011 at 7:47 pm
    I suspect the New Blue F/X is the bottleneck in your workflow. I have noticed that when I use New Blue F/X, the encode time goes way up. A five minute video took hours to encode for Web use.
    Steve Mann
    http://www.mmdv.com
  • Don Cobble
    November 4, 2011 at 7:56 pm
    I have BCC FX Contiuim for vegas – I am not familiar with it but, willing to learn, do you think those would render faster? I have a 1 hour documentary I am working on the render time will be a year at this rate. Got any other suggestions?
    By the way I am very grateful for your help.
    Thank You
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Camera
  • Stephen Mann
    November 4, 2011 at 9:59 pm
    I also have BCC7 but I have little experience with it. If you aren’t doing any keyframing, then it should be fairly easy to drop a BCC7 filter/FX in place of the New Blue. It appears that BCC7 F/X do render faster than New Blue F/X, but that’s based on a very brief use of BCC7.
    Steve Mann
    http://www.mmdv.com
