Activity Forums Apple Final Cut Pro Legacy Render Shortcut does not seem to work
  • Render Shortcut does not seem to work
    Posted by Rodney J on January 24, 2006 at 2:16 am
    Working with G5 FCP5.0.4 and have put a “Render all Unlimited” shortcut button in the top right section of the timeline window and when I click on the button it doesn’t start the render…I still need to go to the sequence menu.
    Any Thoughts??
    RJ
    Captain Mench replied 20 years, 8 months ago 2 Members · 1 Reply
  • Captain Mench
    January 25, 2006 at 6:34 am
    Are you sure you created the button from OPTION-R and not COMMAND-R?? Command-R will only render certain things unless you tell it to. Option-R renders everything.
    CaptM
