Activity Forums Adobe After Effects Render SettingsIssue
  • Render SettingsIssue
    Posted by Dave Simpson on February 24, 2012 at 7:28 pm
    Hello Everyone,
    I’m sure something like this gets asked a lot but I can’t quite find a post that helps so here’s the problem.
    I have created a project that needs to be delivered in both 720 x 480 DV, and DVCPRO HD 1080i.
    I did the compositing in a Comp set to DVCPRO HD 1080 29.97 then just dropped that comp into a 720 x 480 and letter boxed it. When I render the 720×480 comp with DV settings it looks great in Final cut and Media 100. When I render the large comp with DVCPRO HD settings It looks all jagged around the edges.
    The comp consists of a PSD file logo off the top, followed by some video inside of a frame that is animated on and off screen. Both the box the video is in and the video it self is jagged. I have some balloons I created out of solids with Text in them that are animated in after that, and they all have issues around the edges when they move.
    I did try rendering in Animation than exporting it out of final cut to the DVCPRO HD settings but when I bring it back in it has the same problems on a new sequence with the DVCPRO HD settings.
    I have even tried changing to lower filed and not rendering fields and get the same poor result.
    Sadly I am using an old sony media converter box to view this on an NTSC monitor. Could that be the issue?
    It reminds me of other times when I have mistakenly started with a 720×486 comp and tried to render this to DV 720×480 and get that same jagged look.
    Any suggestions would be most appreciated.
    Dave Simpson
    Dave Simpson replied 14 years, 6 months ago 41,618 Members · 1 Reply
  • Dave Simpson
    February 27, 2012 at 3:08 pm
    Hello Dave,
    Thanks for the reply. As it turns out it was the Sony Media converter, the file actually looks okay on a proper HD setup. AND, funnily enough I still do have a 94 Pontiac Grand AM I use sometimes as a Winter Beater/ Take the dog to the beach car!
    cheers
    Dave
