Activity Forums Adobe After Effects Render Settings Preset
  • Render Settings Preset
    Posted by Avrohom Kohn on May 12, 2008 at 8:53 pm
    I have about 200 compositions. I’d like to render one frame of each comp at 4 seconds (for proofing). Here’s what I’ve done so far: I made a preset for the ‘output module’ to give me a JPEG with the proper settings. Then I made a preset for the ‘render settings’, but AE doesn’t let me set a custom ‘time span’ for the preset. I guess cause if it’s set to–say 12 seconds–and you try to render a comp that’s only 10 seconds long with that preset, it won’t work.
    Is there a simple way around this? (rendering one frame from multiple compositions all at the same point in time?)
    A.P.
    TAMotion
    Avrohom Kohn replied 18 years, 4 months ago 22,373 Members · 1 Reply
  • Avrohom Kohn
    May 13, 2008 at 2:54 pm
    I’m aware of that. But all the comps have their work areas already defined, and I’m trying to avoid going into each comp and setting that up. I would like to automate it.
    Thanks anyway
    A.P.
    TAMotion
