Activity Forums VEGAS Pro Render Settings – MSP
  • Render Settings – MSP
    Posted by Rick Hughes on July 11, 2019 at 12:28 pm
    Looking to figure out best render settings for Internet (Facebook or Youtube/Vimeo)
    Previously I had followed advice and used:
    New project
    Match media settings
    Quality = best
    Render as Mainconcept AAC/AVC
    1280 x 720
    Progressive
    2=pass
    Max 12,000,000
    Avg 8,000,000
    However, this is 6+ year old advice, and FB now accepts 1080
    Should I be using instead Sony AVC/MVC
    Having bought ver16 of MSP … have new codec choices
    MAGIX AVC/AAC MP4
    MAGIX HEVC/AAC MP4
    Should I move to H265 and use HEVC ?
    Of course welcome other suggestions if better.
    My source material is typically:
    Complete name : E:\My Videos\…..\P1000820.MP4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42 (mp42/avc1)
    File size : 108 MiB
    Duration : 33 s 33 ms
    Overall bit rate mode : Variable
    Overall bit rate : 27.3 Mb/s
    Encoded date : UTC 2019-07-07 11:42:32
    Tagged date : UTC 2019-07-07 11:42:32
    PANA : ?Q 2
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.2
    Format settings : CABAC / 2 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Ref frames : 2 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Bit rate mode : Variable
    Bit rate : 27.2 Mb/s
    Maximum bit rate : 36.9 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 59.940 (60000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.218
    Stream size : 107 MiB (99%)
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Codec configuration box : avc
    George Dean replied 7 years, 2 months ago 2 Members · 1 Reply
  • George Dean
    July 11, 2019 at 1:35 pm
    Hi Rick,
    I have found the best render is to follow the recommendation of Youtube and maybe up the bit rate and use 2 pass, as you have indicated you currently do (if render times is not an issue). Here is some information from Youtube that can be found on the web…..
    Bitrate
    Bitrate is highly dependent on video codec. YouTube published recommendations on bitrate value. See the table below. If you convert video for YouTube, please try to stick to it.
    Best video bitrate for YouTube upload
    Codec
    Most suitable codecs for YouTube are H.264, MPEG-2 or MPEG-4. These codecs are used in most modern videos, so you’ll hardly need to change this parameter.
    I think form your options Sony AVC and/or Magix AVC would provide for a bit more quality than the Legacy Mainconcept AVC, and if you want to get a bit better with a smaller file size, run a high bit render from SVP through Handbrake using x.264.
    Perhaps other members have a more specific render recipe for HD-60p they feel is better. Also keep in mind that Youtube accept up to 4K now, so if your project are in a higher resolution than FHD, that may be an option to get get higher quality in your Youtube uploads.
    Best Regards……George
