Activity Forums Apple Final Cut Pro Legacy render settings from ae into fcp.
  • render settings from ae into fcp.
    Posted by Alexander Gao on December 15, 2005 at 10:46 pm
    I made a motion graphics composition in after effects, and rendered it to quicktime as an animation. I imported it into fcp and when i rendered it for preview, the resolution had gone bad. Is this because fcp is not set to render under the animation codec? If so, what do i need to do in order to get my graphic into fcp smoothly? Render it under a different codec in ae (because most of my fcp timeline is ntsc dv)? thanks for the help.
    Michael Harnois replied 20 years, 9 months ago 4 Members · 4 Replies
  • Todd Beabout
    December 15, 2005 at 10:57 pm
    Once you drop your AE render into your DV Final Cut timeline, you are essentially dropping the resolution from uncompressed to DV compression. That is the big drawback to DV: graphics.
    If resolution is an issue for you, you should look into upgrading to an uncompressed system, which is quite expensive when you look at I/O options, broadcast quality monitoring, not to mention decks, audio boards, etc… But DV sure is cheap to get into, huh?
    -Todd Beabout
    Vazda Studios
  • Alexander Gao
    December 16, 2005 at 12:48 am
    Thanks for the help Todd,
    Wow, that’s a real bummer. I had no idea that it was so expensive to get rolling with even a DECENT picture, as I’ve only been into this stuff for about 1 and a half years. I thought it was just “buy the right computer ad go”. Anyway, thanks again.
  • David Bogie
    December 16, 2005 at 5:56 pm
    Not stated in the original post: Where are you viewing your output? DV is weird. It looks very good in video, on an interlaced display; a television set or video monitor. DV looks terrible on a computer display.
    bogiesan
  • Michael Harnois
    December 16, 2005 at 7:54 pm
    Check your field dominance as well. Should be rendered in lower field. Upper field render may give you some blur as well.
