Activity Forums Blackmagic Design render settings for Hyperdeck?? working procedure?
  • render settings for Hyperdeck?? working procedure?
    Posted by Tobias Trummer on October 10, 2011 at 2:26 pm
    Sorry for re-posting… but I will give it a try here…
    we try to:
    render SD-mov for Hayperdeck with a LTC-Wav muxed in on 3&4
    Could this work? the aim is, to sync a third device via that LTC.
    Sony Vegas – no success at all
    Premiere – once with original audio YES, another try with LTC: NO
    Today with premiere with same settings: NO even without LTC, that worked few days ago…
    Is there any recommended workflow to achieve that (SD with 1&2 orig. audio / 3&4 LTC) ??
    Are there any more recommendations than:
    “…simply needs to make sure that the file is encoded in 10 bit Uncompressed YUV 4:2:2 with a .mov wrapper, and is in a broadcast standard format that the HyperDeck Shuttle supports. If these conditions are met it should work nicely. If the customer is using Final Cut Pro 7 or Premiere Pro CS5/5.5, and have the Desktop Video drivers installed, they should be able to export using those settings.”
    Tobias.
    Tobias Trummer replied 14 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
