Activity Forums Adobe After Effects Render settings for a DVD?
  • Render settings for a DVD?
    Posted by Oliver De morassé on May 6, 2013 at 9:43 am
    We have shot some HD422 25P footage on a video camera which produces .mxf files. These import into AE CS5 no problem and I set my project’s working space to be HDTV (Rec.709) and selected Linearize Working Space. All post-editing has been completed.
    I need to produce the output for a DVD, which can be played on a normal widescreen TV (here in Europe). What render settings do I need to use i.e. Format, video output settings etc.
    Many thanks for your help.
    Oliver De morassé replied 13 years, 4 months ago 2 Members · 6 Replies
  • Oliver De morassé
    May 8, 2013 at 11:25 am
    Hi Dave, thanks for your feedback.
    I use AME CS5 to render my compositions. The following presets are shown:
    Unfortunately, I see nothing for a DVD. I want the videos to be at the best possible quality for the DVD. Hence, I selected “H.264” Format and preset “HDTV 1080p 24 High Quality”:
    You mention I should create a “720×576, 25fps file in mpeg2”. I don’t quite understand why – sorry, but I have never created a DVD before. Also, which settings should I change on this preset (pixel aspect ratio, profile, level, bitrate settings/encoding etc).
    Regarding DVD authoring software, have you had any experience of ‘free’ tools such as DVD Flick or DVDStyler – what speaks for Adobe Encore?
    Many thanks, Oliver
  • Oliver De morassé
    May 8, 2013 at 1:59 pm
    Another thing, I can’t find out where I can purchase Adobe Encore – is this only part of the creative suite or in the Adobe cloud?
  • Jeff Pulera
    May 8, 2013 at 2:15 pm
    Hi Oliver,
    Adobe Encore cannot be purchased by itself – it comes with Premiere Pro, or if you buy a suite such as Production Premium that includes PPro then you get Encore of course.
    As Dave pointed out, DVD content must adhere to specific…specifications. DVD is always MPEG-2 standard definition, basically 720×480 for NTSC and 720×576 for PAL. There are a few uncommon variations, but the NTSC and PAL settings are pretty firm.
    So, your DVD cannot be “HD”, nor can it be “H.264”, or anything other than “MPEG-2 for DVD”. Period. If you were to import a video into Encore that was HD and/or H.264, Encore would simply Transcode it to the proper standard definition MPEG-2 anyway, no way around it.
    Thank you
    Jeff Pulera
    Safe Harbor Computers
  • Oliver De morassé
    May 8, 2013 at 4:21 pm
    Thanks Jeff and Dave for your replies. Now it all makes a little more sense!
    In AME I found under Format the following choices:
    … and here we go, there is a MPEG2-DVD option with the following settings!!!:
    To get the best possible quality video (I shot at HD422 25P), dod I need to set Quality to the maximum (i.e. 5) and what about the bitrate settings? BTW, what are GOP settings?
    Thanks for all your tremendous help!
    P.S. @Dave – Yes I am in Munich and the beer is great… especially on nice hot sunny days like today ;O). I will send greetings to the Paulaner biergarten and also the Wiesn (Oktoberfest).
  • Oliver De morassé
    May 12, 2013 at 4:21 pm
    I have done a little experimenting over the weekend.
    I used the “MPEG2-DVD” format preset and then changed quality to 5 and bitrate settings to CBR, 9 Mbps. The video looks just fine – however, I am not 100% happy with the quality of output. On my 46″ TV, the whole movie is pixelated and not as high quality at what I actually shot. If I render to a .mp4 and view it on a PC, the quality is much higher. Am I doing something wrong here?
  • Oliver De morassé
    May 13, 2013 at 7:58 pm
    Thanks for your feedback Dave.
    Sorry, I am still a little confused…
    1. I tested several DVD Authoring Programs – I was able to create DVDs with 9 megabytes/sec. (not 6) – however, the quality did not really improve.
    2. When I look at a film on DVD on my TV – the quality is great… why can’t I create something similar?
    Sorry for the dumbo questions – I have never created a DVD before and the learning curve is steep!
