Activity › Forums › VEGAS Pro › Render settings for 2.7k 60fps on Blu-ray
  • Render settings for 2.7k 60fps on Blu-ray
    Posted by Eric Hebert on August 16, 2019 at 2:02 pm
    Hi guys,
    Can you help me with the render settings on VP17?
    I shoot with my Gopro 7 black in 2.7k 60fps.
    I want the best result because I need burn my project on a Blu-Ray disk without loosing the quality. Thank you in advance!!!!
    Eric
    Sebastian Fudali replied 7 years, 1 month ago 3 Members · 6 Replies
  • Sebastian Fudali
    August 19, 2019 at 8:02 am
    With 2,7K you are bound to lose quality.
    BD supports only 2K and 4K (with HEVC).
    The question is did you REALLY record in 60p, or in NTShitC in 59,940p.
    Your options are either to downscale it to 2K, or upscale it to 4K to HEVC.
    But your best bet is to crop to 2K, of course if your frame composition allows for that, if you have uneeded background.
    As for bitrate, I don’t remember if BD supports compressed audio of GP, but you can uncompress it to 16/48 LPCM. Max video bitrate is 40Mbps, so set to standard 36Mbps.
    And you’re good to go.
    But next time stick with proper natural number framerate of 25, or 50 fps, makes life much easier.
  • Geoff Candy
    August 19, 2019 at 6:57 pm
    The good news is that the GoPro 2K7 is progressive. Simply render out to a standard MainConcept MPEG2 BD 1280x720P template. (video stream). Render out the audio as ac3pro or similar. Add files to DVDA and it should be accepted. Let your TV do the upscaling to 1920×1080. It will look fine. Never fails in PAL land.
    BD standards are 1280x720p or 1920x1080i 50fps in PAL or 59.97 in NTSC land.
    Make sure your timeline properties match your clips/files.
    Best of luck.
  • Sebastian Fudali
    August 19, 2019 at 7:04 pm
    Nah. Render to full HD instead of regular HD.
    BS is 25 frames per second or 50 fields per second. If it’s natively progressive, then keep it that way.
    Crop, or resize to 1080p.
  • Geoff Candy
    August 19, 2019 at 8:11 pm
    Having rendered or cropped to full HD how do you burn your BD so as to remain progressive?
    Am somewhat puzzled as my understanding is that BD accepts 1080i or 720p.
    1080p is not a BD standard in 60 or 50 fps. Maybe 1080p 25fps but not so good for fast action. Not a format I have used.
    Enlighten please?
  • Geoff Candy
    August 19, 2019 at 8:18 pm
    Blu-ray Standards
    1920×1080 29.97 frames interlaced / 59.94 fields (16:9)
    1920×1080 25 frames interlaced / 50 fields (16:9)
    1920×1080 24 frames progressive (16:9)
    1920×1080 23.976 frames progressive (16:9)
    1440×1080 29.976 frames interlaced / 59.94 fields (16:9)
    1440×1080 25 frames interlaced / 50 fields (16:9)
    1440×1080 24 frames progressive (16:9)
    1440×1080 23.976 frames progressive (16:9)
    1280×720 59.94 frames progressive (16:9)
    1280×720 50 frames progressive (16:9)
    1280×720 24 frames progressive (16:9)
    1280×720 23.976 frames progressive (16:9)
    720×480 29.97 frames interlaced / 59.94 fields (4:3/16:9)
    720×576 25 frames interlaced / 50 fields (4:3/16:9)
  • Sebastian Fudali
    August 20, 2019 at 4:30 am
    BD supports not the progressive FHD:
    https://en.wikipedia.org/wiki/Blu-ray#Video
    The trick is in HEVC.
