Activity › Forums › VEGAS Pro › Render setting for SD footage 720 x 576 25fps PAL 4:3
  • Render setting for SD footage 720 x 576 25fps PAL 4:3
    Posted by Jane Wielecki on December 13, 2013 at 10:47 am
    Hi, I need some expert advice please.
    What are the best render settings for my footage, which is:
    SD 720 x 576 25fps PAL 4:3 (Australia). Shot in 2005.
    I will use DVD Architect. It will be shown on widescreen TV.
    I am going to have black pillars on either side of footage as I don’t want to stretch or crop.
    Can I render to Blu Ray or is DVD my only option?
    I understand that Blu Ray won’t improve quality of SD but there will be more space on the blu ray disk. I own a Blu Ray player.
    My project properties are as follows:
    Template: PAL DV (720 x 576, 25.000 fps)
    Field Order: Lower
    Pixel Format: 8 bit
    Render Quality: Best
    Motion Blue: Gaussian
    Deinterlace method: Blend
    AUDIO
    Bus Mode: Stereo
    Stereo Busses: 0
    Sample Rate 44,100
    Bit Depth: 16
    Resample and Stretch Quality: Best
    Any advice would be much appreciated.
    Kind regards,
    Jane
    Jane Wielecki replied 12 years, 9 months ago 2 Members · 6 Replies
  • Stephen Mann
    December 13, 2013 at 5:01 pm
    Actually a BluRay disk will be slightly better looking than a DVD. Because you have more room, you don’t have to compress as much and you enjoy a higher bitrate. Compression and lower bitrate for a DVD compromises the overall quality.
    Just find a DVDA template in the Main Concept section of the “Render As” dialog. If you find one with the = next to it, then it’s a match for your media and will be the best to use. Otherwise, pick one that is the closest to your media.
    Don’t forget the AC3 audio file.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Jane Wielecki
    December 14, 2013 at 11:17 am
    Hi Steve, thanks for your response.
    I going to use;
    MainConcept MPEG 2
    TEMPLATE: DVD Architect PAL video stream
    When I eventually burn to blu ray in DVD Architect, what bit rate should I use?
    More questions to follow no doubt. I really appreciate your advice Steve.
    Regards, Jane
  • Stephen Mann
    December 14, 2013 at 3:31 pm
    I rarely do BluRay, and only one client in the past few years have requested it. You don’t say how long the video is, but for most SD projects, just use the defaults.
    Steve Mann
    http://www.mmdv.com
  • Jane Wielecki
    December 14, 2013 at 8:32 pm
    It is 2 hours long.
  • Stephen Mann
    December 14, 2013 at 9:20 pm
    Start with the defaults. If the resulting iso file is under 23098.0 Mb then it will fit.
    Steve Mann
    http://www.mmdv.com
  • Jane Wielecki
    December 14, 2013 at 9:40 pm
    Ok, thank you!
