Activity Forums Maxon Cinema 4D Render Seperate Layers not object buffer
  • Render Seperate Layers not object buffer
    Posted by Tim Rice on May 17, 2013 at 3:48 am
    So i’m setting up a scene where i can use after effects to mask text while keeping the background. Using object buffers won’t work because it will leave a hole in the background.
    The only solution I’ve come up with is using the compositing tag and render the scene twice, one for the foreground and one for the background.
    But I’m left thinking there’s a more elegant solution?
    Any help would be appreciated.
    Adam Trachtenberg replied 13 years, 4 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    May 17, 2013 at 11:48 pm
    As you figured, rendering twice is the only option.
