Activity Forums Apple Final Cut Pro Legacy Render Selection Problem
  • Render Selection Problem
    Posted by Craig Bass on September 30, 2008 at 6:24 am
    For some reason my FCP will not allow me to “Render Selection”; instead, it forces me to render the entire project every time.
    When I either hit the hot keys for render selection, or access it from the drop down menu, it merely flashes the progress bar for a millisecond, and that’s it – leaving the selection unrendered. The clip, or selection, in question is, of course, selected.
    What is going on here?
    Any ideas?
    *Craig*
    Laura Mcrae replied 17 years, 4 months ago 3 Members · 2 Replies
  • Andy Mees
    September 30, 2008 at 6:40 am
    Under the Render Selection submenu you will see that there are many different conditions than you might want to render or not … you must select all the conditions that you want to be applied prior to invoking the render selection command
    Heres an example: suppose I place a clip in the timeline that FCP can play back in full quality without need for any render whatsoever, and then I place next to it a clip that FCP can play back only in preview quality and finally I place one that can not be played back at all without rendering. and I then select all three and choose Render Selection … how should FCP handle this? should it render all clips even though one of them actually doesn’t need rendering at all, and another can be previewed anyway without render? FCP allows us to control what is and isn’t rendered by any given command through our choices in the Render sub-menu’s. So in this case I could choose that Render Selected only applies to Needs Render clips, or to Needs Render and Preview quality etc
  • Laura Mcrae
    April 30, 2009 at 3:18 pm
    Hi Craig
    I realise your post was some time ago but wanted to check if you had found a solution to this problem. I am encountering exactly the same thing ie. I can only render the whole sequence and am unable to render just my selection from it.
    If you figured this one out it would be great to know the answer.
    Laura
    Laura
