Activity Forums Maxon Cinema 4D Render scene with Vray Light Expression in alpha channel?
  • Render scene with Vray Light Expression in alpha channel?
    Posted by Simon Huang on December 30, 2014 at 9:35 am
    Hi, I have added a VRay light to a scene but have absolutely no idea how to render just the model in alpha channel. Normally you can just check “seen by camera camera off” or use a shadow catcher. However, in this case, since an EXR file has been used in the layer shader under Area Light> Light Dome> Layer, i can’t seem to turn “seen by camera off” and there is no option for that.
    So, is there a way i can render the model in alpha channel? Been racking my brain all day 🙁
    Thanks so much!
    Simon Huang replied 11 years, 7 months ago 1 Member · 3 Replies
  • Simon Huang
    January 2, 2015 at 5:55 am
    Anyone? 🙂
  • Simon Huang
    January 12, 2015 at 2:04 am
    Turning “invisible” on seemed to work abit. However, everything is invisible in the final render….
  • Simon Huang
    January 12, 2015 at 2:05 am
    Turning “invisible” on seemed to work abit. However, everything is invisible in the final render…. Does anyone have any ideas? There should be a way..
