Render Replace + ProRes 4444 Problems
Recently, I used Render and Replace to render an AE composition with alpha. That part worked fine, but every time I tried to play the section with the rendered clip, Premiere crashed, almost instantly. That was v.22. Now in v23, this appears to have been fixed in Premiere, but Media Encoder is crashing on that same clip.
Related, if I “unrender” the clip to revert back to the mogrt, it appears to work, but nothing shows on screen. In order to get the clip to show on screen, I have to restart Premiere.
Two questions: Does anyone else see this? And what alternative would you use for alpha channel renders? Adobe says Cineform in their help, but does not provide a preset. Still trying to get one to import.
