Activity › Forums › Adobe Premiere Pro › Render & Replace Codecs in Premiere Pro 2017
  • Render & Replace Codecs in Premiere Pro 2017
    Posted by Per Haar on February 5, 2017 at 11:44 am
    Can anyone enlighten me and tell me the difference between the “MXF OP1a” and the “DNxHR/DNxHD MXF OP1a” that pops up when I want to render & replace a clip in Premiere Pro 2017. And also the difference between “AVC Intra” and “DNxHD”
    I’m trying to find the best workflow for rendering & replacing an After Effects Comp, on the timeline, as close to uncompressed as possible…..
    – what would you do?
    /Per ☺
    Tero Ahlfors replied 9 years, 7 months ago 2 Members · 1 Reply
  • Tero Ahlfors
    February 5, 2017 at 1:27 pm
    The MXF OP1A codecs are mostly used for broadcast (XDCAMHD is a pretty universally used one).
    You can find info on all of these in Wikipedia but I’d probably use DNxHD for what you want to do.
