Activity Forums Adobe After Effects Render Question
  • Render Question
    Posted by Big Beres on August 7, 2007 at 10:42 pm
    I have a AE Comp that’s 1024 X 576 that I’ve rendered into Quicktime (will be used at a DVD menu)
    I would like to post this comp onto my new website, what Quicktime render settings do I use so this comp can play on my website but that will still keep the same amount a quality but not using 1024 x 576 but keeping that sort of ratio . I’m not very clued up on render setting.
    I hope I’ve explained myself well enough.
    Thanks in advance for you help.
    BB
    Big Beres replied 19 years ago 2 Members · 2 Replies
  • Michael Duff
    August 7, 2007 at 10:55 pm
    hi there … this could be a better question for the Compression Techniques forum ….. i normally use another piece of software for doing this … like Sorenson Squeeze, or Compressor ….
    i usually go 512×288 … this is still pretty big and you could even go smaller ….
    then choose a codec… h.264 is great but needs qt7…. qt MPEG4 is good and only needs qt6 …sorenson3 is another good qt codec…. wmv9 is good for windows people without quicktime …flash is good now too..
    there is always going to be a loss in quality, size and compatibility… you just need to compromise and pick a happy medium that will suit most of your viewers….
    maybe do some tests and find a setting you are most happy with… then if you have some more questions you should try the Compression Techniques forum…. good luck
  • Big Beres
    August 8, 2007 at 1:21 am
    Thanks for that…. It worked just the way I wanted it too…..
