Activity Forums Maxon Cinema 4D Render question
  • Render question
    Posted by Marc Lucas on March 6, 2011 at 9:25 pm
    I had two rotating text objects in the scene the render settings where set firstly to a QT then tried TGA sequence and both times I have tried to render all Cinema splits out is a single tif of the scene. I have looked at the obvious like how many frames are set etc and they were all ok. Is there something else I’m missing?
    I have consequently set up a new project with the same text elements and now the render is OK.
    Mmmm.
    Tim Shetz replied 15 years, 6 months ago 2 Members · 1 Reply
  • Tim Shetz
    March 7, 2011 at 6:42 pm
    In your render settings you need to make sure “all frames” is selected. By default it will only render out the “current frame”
    __________
    Tim Shetz
    c4dtraining.com
