Activity Forums Adobe After Effects render que settings help
  • render que settings help
    Posted by Avril Wallace on August 24, 2006 at 4:54 am
    Im rendering a file as an animated gif but it comes out being a huge file size! Can anyone help to set the correct settings so that it is small ehough for web but is pretty good quality too? Is this possible.
    Any help would be awsome.
    Avril
    Glenn Moore replied 20 years, 1 month ago 2 Members · 1 Reply
  • Glenn Moore
    August 27, 2006 at 7:05 am
    It depends on your settings, what are your selections? I generally use the Animation setting and render as a Quicktime movie. THe size of your project can depend on your resolution as well. Are you setting to 320 x 240, 640 x 480, or much higher? Finally, despite your file size at this point, you can always look at using an app like Squeeze (from Sorenson) to convert to a size that is more appropriate to your needs. There are several presets for several uses.
