Activity Forums Apple Final Cut Pro Legacy Render Quality
  • Posted by Mario Golfari on July 8, 2009 at 7:18 pm
    I´ve edited an animated short on final cut (Quicktime compression: Animation;720×480).
    When I press play on the timeline the canvas image becomes brighter, but I didn´t think anything of it until I exported a PNG sequence and opened it in After Effects- the video starts with a fade-in from black and when the fade-in ends, the image abruptly becomes brighter from one frame to the next, as if it were reading the same thing I see on the FC timeline.
    When I export thru quicktime conversion using Animation, the same thing happens. The problem goes away when I add a filter to all the video clips. Or else if I export thru quicktime movie only that the quicktime ends up weighing 8x more than if I export thru quicktime conversion (I need to compress for web and all the FC options for a good compressed file haven´t given me good results).
    I´m still trying everything but its been 4 days and I´m starting to loose it!
    J. Tad newberry replied 17 years, 1 month ago 3 Members · 4 Replies
  • Rafael Amador
    July 8, 2009 at 8:43 pm
    Hi Mario,
    Try “Render in 8b RGB”. In the sequence setting.
    rafael
    http://www.nagavideo.com
  • Mario Golfari
    July 8, 2009 at 10:23 pm
    The Animation compression settings doesn´t let me adjust video processing…
  • Mario Golfari
    July 8, 2009 at 11:08 pm
    OK, I see, I don´t need to have the sequence setting on Animation compression (this was what was making it brighter when I played it).
    Thank you very much.
  • J. Tad newberry
    July 21, 2009 at 7:17 am
    Very strange, i haven’t had this problem before. Rendered an 8-bit NTSC sequence and the resulting QT is very pixellated/blocky. I’ve trashed prefs, same thing. I can scrub through the sequence and it looks great. Pausing on a single frame looks good, but doing the render results in this low res…and yes on export, i am choosing use “Current Settings”, but no dice…
    Thanks again!
    J. Tad Newberry
    Big Ya Productions
    Mac Pro 2.66 GHz Quad-Core
    3 GB RAM
    http://www.bigya.tv
