Activity Forums VEGAS Pro Render process hangs – but file IS created.
  • Render process hangs – but file IS created.
    Posted by Matt Schwartz on January 8, 2008 at 12:27 am
    **DON’T ANSWER THINK PROBLEM IS SOLVED. Hi I am rendering MPEG-2 to the architect template NTSC format and all goes well, but at the very end when it reaches 100%, and I have checked the box for it to close when finished, the render window hangs or APPEARS to hang to end as the process cannot be canceled, IT DOES NOT RESPOND, , the drive light is on continuously and I reluctantly have to close Vegas Platinum itself fortunately it does then allow me to cancel the process gracefully and platinum allows me to save. In this case, I create an intact 2.4 Gig file …..any idea why this is happening…or is it doing something meaningful when the drive light is on continuously and should I just wait longer for it to possibly terminate…….thanks for all your excellent help…this product is like a labyrinth, it’s just got endless side passageways……………..right on….
    Matt Schwartz replied 18 years, 8 months ago 1 Member · 1 Reply
