Activity Forums Apple Motion render problems with some frames..
  • render problems with some frames..
    Posted by Stefan Kroesbacher on May 5, 2009 at 1:47 pm
    hi all,
    i’m facing serious trouble with a project of mine.
    it’s extensively comp’d, with different transfer modes, 3d particles etc.
    problem is, in half resolution render everything’s fine
    in full (1080p) either in compressor or motion itself,
    some frames make trouble..
    transfer modes and masks seem to fail, leaving the frame with
    artifacts…
    next frame’s good again…
    then again somewhere problem…
    known problem?
    what makes motion fail?
    opengl?
    ram?
    10.5.6, x1900xt
    thanx for input
    stefan
    Stefan Kroesbacher replied 17 years, 4 months ago 2 Members · 2 Replies
  • Stephen Smith
    May 5, 2009 at 3:25 pm
    The only time I’ve ever had a problem like that is when the Render Quality is not set to Best when it should be. Make sure everything is set to Best. If that doesn’t work I would make sure I have the newest update of Motion. Hope this helps.
    Lone Peak Productions
    Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
  • Stefan Kroesbacher
    May 5, 2009 at 6:16 pm
    found the problem:
    “Beam” Generator makes the trouble.
    strangely in ram preview everything works,
    but whichever setting i use, expoting in full
    res an best or normal doesn’t work.
    i think i have to render proxies for the beam effekt…
    sad but true…
    or simply my x1900xt can’t handle the project.
    will try with a new machine and a 4870 in a few dayz
    thanx
