Activity Forums Boris FX Render Problems with Boris Red and Premiere Pro 1.51
  • Render Problems with Boris Red and Premiere Pro 1.51
    Posted by Madmax1234 on October 7, 2005 at 8:29 pm
    Hi guys.
    I have some strange problems with Boris Red and Premiere Pro.
    First of all a little overview over the software and versions.
    I’am using Boris Red 3.02 with Premiere Pro 1.51 german.
    Now if i make a dissolve from one clip to another and maybe choose
    as a transition effect “2 face cube” and watch the preview in Red
    then everthings looks fine. So i klick “apply” in Red and i’am back in
    Premiere. If now play the transition in Premiere with preview quality
    then everything still look fine, but if i now render this part or
    switch the quality level to high quality in premiere and playback
    than everything looks strange stretched or someting. It has not the
    aspect. Don’t know how to discribe it.
    I hope that maybe somebody of you guys can help me out of this mess.
    Best regards,
    Max.
    Madmax1234 replied 20 years, 10 months ago 1 Member · 1 Reply
  • Madmax1234
    October 7, 2005 at 9:00 pm
    Hi it’s me again.
    Now i know where the problem is.
    If i’m doing the same effect in a premiere project witch is not using fields
    then it works without problems.
    So now i know the field are the problem, but how can i now do the Boris Red effects
    in a project witch does use field. I think every project uses fields, don’t they.
    Please help me!
    Max.
