Activity Forums Apple Final Cut Pro Legacy Render Problems Quicktime to Mpeg
  • Render Problems Quicktime to Mpeg
    Posted by Martyn Morris on March 7, 2012 at 9:41 am
    I have a Quicktime file that is 1920*1080 wit a Animation codec and I would like to convert it to a .ts or .mpg file MPEG-2 video and MPEG Layer , 48000Hz Stereo(LR) wit a Data rate of 15 mbits/s.
    I have used Compressor, FFMPEGX, MPEG Streamclip, iSkysoft Media Converter
    Im not sure how to input the 15 mbps. The client has asked for these exact requirements and keeps sending back every render as wrong.
    Any help would be gratefully recived.
    Martyn.
    Jerry Hofmann replied 14 years, 6 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    March 7, 2012 at 4:57 pm
    That’s a data rate you can select from Compressor’s MPEG video settings. Look in the Inspector once you’ve selected a preset to start with.
    Chances are they want a program stream, and not what would be made for a DVD SP project… That you can select from the Inspector as well.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
