Activity › Forums › Adobe After Effects › Render problems
Render problems
Posted by Victor Camacho guerrero on July 23, 2012 at 8:39 amHello everyone,
I have a scene done in after effects, and when I render, some green spots shows in the scene between the seconds 00:04 and 00:06.
However in after effects these spots does not show up.
It looks like a problem from rendering. I tried with quicktime and codecs photojpeg and h264.
Anyone has any idea?
Victor Camacho guerrero replied 14 years, 1 month ago 4 Members · 7 Replies -
Roland R. kahlenberg
July 23, 2012 at 12:08 pmWhich version of AE are you using?
Try rendering without MP to see if the issue persists.
HTH
RoRKIntensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer -
July 23, 2012 at 1:03 pmHi Roland,
thanks for your reply. I am using AE5
sorry, what do you mean with MP? music?
thanks
July 23, 2012 at 3:03 pmMP=Multi-processing.
Switch off multi-processing to see if the render issues persist. If the problems continue, then let us know more about the footage/layers/effects/comps that are being used.
Cheers
July 23, 2012 at 3:05 pmHi Roland,
oh cool , sorry for my english. Well the multiprocessing is always off due to my technical limitations. Therefore it has to be something else.
Maybe some is because quicktime compression?
many thanks
Walter Soyka
July 23, 2012 at 4:13 pmThey look like elements in a lens flare effect, perhaps?
What bit depth is your project?
If there is some sort of clipping occuring, perhaps you can tone them down a touch with the HDR Highlight Compression effect?
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Cassius Marques
July 23, 2012 at 9:26 pmoptical flares does that sometimes when you enable flicker and it goes somehow below zero. Just tweak it’s settings and it should work
July 24, 2012 at 8:53 amhi guys thanks for the reply.
i have some optical flares , as you said it is maybe the reason, I could try work on it as Cassius Marques said.
I am working in 32 depth. Converting to 16 again, basically change the whole color-mood of the scene.
The funny thing is, when i preview using the RAM that part in AE, the scene looks fine, but those green spots show only after rendering, that is why i was thinking it was something of the codecs.
