Activity Forums Adobe After Effects Render Problems
  • Render Problems
    Posted by Faraz Mozafarian on March 12, 2010 at 8:26 pm
    Hello,
    I ham having problems with my output. I have a comp with some glows and various effects. However, when I export and import into final cut some of the glows are now gone. and various layers are getting cut off like adjustment layers and things. I have tried exporting with the ANIMATION CODEC and the APPLE PRO RES 4444. Should I be using another format? am I missing some settings?
    Please help as this is for my job and I need to get this right.
    Thank You!
    Faraz Mozafarian replied 16 years, 6 months ago 2 Members · 4 Replies
  • Faraz Mozafarian
    March 12, 2010 at 8:39 pm
    Ok,
    So it works when I export to Apple Pro Res 422(HQ) anyone know why that is?
  • Bob Root
    March 12, 2010 at 8:40 pm
    Check your render settings to make sure that your effects aren’t set to “off”.
    Bob
  • Bob Root
    March 12, 2010 at 8:42 pm
    Oops.. my bad.
    Didn’t see that this is an export. Can you render your files and take them into FCP?
  • Faraz Mozafarian
    March 12, 2010 at 8:45 pm
    Yes. I have tried rendering with ANIMATION, PRO RES 4444 and PRO RES 422. The only one that works in PRO RES 422.
