Activity › Forums › Apple Final Cut Pro Legacy › render problems
  • render problems
    Posted by Michael Stipe on January 25, 2011 at 7:01 pm
    After I render my sequence and it finishes, part of the sequence needs to re-render again. It looks like it is only above one specific shot that appears throughout the sequence. It is a yellow “unlimited” render. That clip has the exact same clip settings as my other clips – the biggest difference is that I have a smoothcam filter on it. The weird thing is that it has only done that 2-3 times. Most of the time everything works normal.
    Sequence settings – 1920×1080 HDTV 1080i (16:9), Apple ProRes 422 (HQ) quicktime compressor setting, the render control is “same as sequence codec”
    Clip settings – it’s an AVCHD clip, the only difference in settings from the sequence is the compressor says Apple ProRes 422 (not HQ)
    Any ideas? Let me know if you need more information about workflow.
    Michael Stipe replied 15 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
