Activity Forums Apple Final Cut Pro Legacy Render problem? Issue with cross dissolves; making clips jump back and forth
  • Render problem? Issue with cross dissolves; making clips jump back and forth
    Posted by Kay Es on May 20, 2009 at 7:36 am
    Hello all,
    I am having an issue with what appears to be a rendering problem, because this doesn’t happen until my clips are all rendered.
    I am currenly working on a wedding video, using previously recorded .mov files. I am trying to make my clips cross-dissolve, but as soon as the clip renders, the clip doesn’t replay correctly. What happens is that the clip will do its dissolve into the next clip, but then (for a split second) replays the clip that was being cross-dissolved. So, for example, I have a crowd shot dissolving into 2 people walking down the aisle, and when the dissolve ends, the people seem to “retrace their steps,” and appear a few paces back, and then re-walk down the aisle.
    I am not sure what to do to prevent this from happening, but I have a few more details that may narrow down as to what the problem is, and why I think it may have to do with rendering.
    In the area of the timeline that usually turns red when a clip needs rendering, a small white dash appears above the problematic part of my video, i.e. where the video “jumps,” (this is what I have come to call the back-tracking). I have smooth-cam on all of my clips, so that may be some of the problem in rendering. Also, I had accidentally moved all of the render files to a different location, so when prompted for them upon opening the project, I chose the new location, and the problem seemed to go away momentarily. Then, though, it needed to “re-analyze” the clips, and after 3 hours of analysis, the problem returned. My settings are on unlimited RT. ALSO, I tried just exporting the video to see if it would just fix itself, and in the exported copy it did the little jumps as well.
    I am working on a deadline and I am driving myself crazy, so all of your help is much appreciated.
    Do you have any suggestions or solutions?
    Sincerely,
    Kyle
    Sarah Mcmillan replied 17 years ago 4 Members · 6 Replies
  • Jerry Hofmann
    May 20, 2009 at 11:58 am
    What are your sequence’s settings? HDV? DV??
    Might try baking the video… i.e., export the clips which show the problem as self contained movies, then cut them back in.
    Jerry
  • Rafael Amador
    May 20, 2009 at 12:35 pm
    Deleting the “Constant Frames” renders may solve this problem.
    rafael
    http://www.nagavideo.com
  • Kay Es
    May 20, 2009 at 4:06 pm
    How does one delete the constant frames?
    Also, the settings are in HD, and I have tried exporting and re-importing, but the same problem occurs
  • Kay Es
    May 20, 2009 at 4:27 pm
    Excuse my last post, I tried deleting the constant frames and still I have no luck.
    Do you think it may be render settings or something?
  • Rafael Amador
    May 20, 2009 at 4:59 pm
    Hi Kyle,
    I really don’t know what to suggest you.
    Try re-render some of the transitions.
    Rafael
  • Sarah Mcmillan
    September 10, 2009 at 11:00 pm
    hi kyle,
    did you ever work out how to fix this? i am having the same problem
    thanks
    sarah
