Activity Forums Adobe After Effects Render problem when cropping image
  • Render problem when cropping image
    Posted by Anders Carlsson on July 22, 2009 at 11:41 am
    I’m doing a very simple crop of a picture, should be a 1 minute thing, but it’s not.
    Description: I have a 1280×720 image, that I want to crop to 1280×564.
    Process: I make a 1280×564 size comp and drop my 1280×720 into it. I have also tried the crop option in the render que.
    Result: My blacks become grey. If I render with the same settings at 1280×720 everything is fine, but as soon as I do any cropping, I loose my blacks.
    I have tried rendering the crop to tiffs first, and then importing that sequence and render out as a wmv or avi, but same problem occurs. Somehow the crop changes the black level. Anyone have any solution to this? Source is a wmv with compression none.
    Thank you in advance!
    Anders Carlsson replied 17 years, 2 months ago 2 Members · 2 Replies
  • Ben Rollason
    July 23, 2009 at 12:30 pm
    Very curious. This sounds like a formats thing. What format are you rendering out?
    For starters, I’d recommend that you export both versions as a Lossless Quicktime and see if they differ. If they don’t, then probably whichever format you are using only likes certain pixel dimensions?? mpeg?
    I can’t say I’ve ever seen pixel size affecting gamma or levels though, although gamma is a thorny subject.
    -Ben.
    http://www.benrollason.com
  • Anders Carlsson
    July 23, 2009 at 8:35 pm
    Hi all,
    thank you for you responses.
    The scource is a 1280×720 WMV file that I converted to a TIFF sequence to work with. I converted it becuse AE didn’t seem to work very good with WMV files. The stuff I did on the sequence was just adding some text. Anyway, if I render this to my output format, which is either WMV or AVI (must play in Windows Media Player, any other suggestions?), everything works great, my blacks are black.
    When I crop it by using a smaller comp or by using the crop options in the render que, my blacks become grey.
    I export the 1280×720 final composite to a TIFF or Quicktime format, then import that to AE, crop it and render out, I loose my blacks.
    If I render out a TIFF sequence of the final 1280×720, and open it in Photoshop, crop it, and render out as a new TIFF-sequence that I import into AE and render to a WMV or AVI, I loose my blacks.
    Even if I just take one frame of the TIFF sequence, open it in Photoshop, crop it, save it, open in AE and render out as a WMV or AVI, the blacks become grey.
    Suggestions?
