Activity › Forums › VEGAS Pro › Render problem – Vegas Pro 16
  • Render problem – Vegas Pro 16
    Posted by Eric Hebert on August 14, 2019 at 11:30 pm
    Hi guys,
    I’m trying to make a movie with a few clips from my GoPro and I have a problem. My clip are 2.7k 60ips. Everytime I try to Render and burn on a Blu Ray the video and the audio render is ok. The problem is after that. It says Failed to connect to a IPC port : cannot find the specific file. Please help me !!!!! I put too much time in that project to let go. Thanks !!!!!
    John Norton replied 7 years, 1 month ago 3 Members · 4 Replies
  • Jeff Lee
    August 15, 2019 at 2:31 pm
    Why not re-code in HandBrake?
  • John Norton
    August 15, 2019 at 2:33 pm
    Hi Eric I think this might fix the issue, this is a recurring issue, not now in VP17. Assuming you have another version of VP that IS working ok, just change the VP numbers accordingly. Found on the Magix VP forum …
    “This was Oldsmokes solution” …
    “Here is a little bit more. If you have VP14, rename the folder C:\Program Files\VEGAS\VEGAS Pro 15.0\bdmux to something like bdmux-vp15. Copy the same folder from VP14 over to VP15.”
  • Eric Hebert
    August 16, 2019 at 1:59 pm
    Thank !
    With VP17 everything work.
    Can you help me with the render settings?
    I shoot with my Gopro 7 black in 2.7k 60fps.
    I want the best result because I need burn my project on a Blu-Ray disk without loosing quality.
    Thank you in advance!!!! Eric
  • John Norton
    August 16, 2019 at 3:29 pm
    Not sure I can be of great help. I guess it’s all about data rate, codecs used. Maybe use as high a data rate as is practicable for the output media.
