Activity Forums Apple Final Cut Pro Legacy Render Problem – Green flickering artifacts
  • Render Problem – Green flickering artifacts
    Posted by Dan Shott on March 25, 2010 at 8:21 pm
    Hey everyone,
    We’re seeing random artifacts showing up in some of our Final Cut Pro renders. It appears as a flickering green bar at the bottom of the frame. If you kill the render file the green flickering bar goes away, but it’s time consuming to have to watch through everything looking for the problem and there’s always the worry of missing some on outputs.
    My initial thought would be that it has something to do with the fact that we’re using the SD Apple ProRes 422 codec for the footage as they only other time I’ve seen this happen was also on a ProRes show (we normal work in DVCPRO HD, DV, or 8-bit uncompressed)
    It appears to happen mostly (possibly exclusively) on shots that are sped up or slowed down.
    Here is an example of what we’re seeing https://vimeo.com/10441342
    Info on our setups: Problem seems to be showing up on Intel and Power PC machines, all machines running Leopard with FCP 6.0.6, capture settings for footage is AJA Kona LH: 525 29.97 Apple ProRes 422, seeing it in multiple bays
    Any suggestions on cause/solution would be greatly appreciated!
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Robb Harriss replied 16 years, 5 months ago 2 Members · 5 Replies
  • Robb Harriss
    March 25, 2010 at 11:28 pm
    what codec are you rending out in?
    Non-linear: all the time and nothing but.
  • Dan Shott
    March 25, 2010 at 11:37 pm
    We’re using Apple ProRes 422 for everything.
  • Robb Harriss
    March 25, 2010 at 11:39 pm
    so you’re exporting your renders in ProRes? for what use?
  • Dan Shott
    March 25, 2010 at 11:53 pm
    Our editors will fully render out a show then we in the assist bay will take their sequence and export it for viewing, ftps, dvd, etc. The renders are used in the making of the quicktime so we don’t have to rerender the show for output.
  • Robb Harriss
    March 26, 2010 at 12:28 am
    the normal process for this would be to render out a Quicktime MOV
    I know that if you use h264 you can get some green banding under certain circumstances.
