Activity Forums Adobe Premiere Pro Render Problem
  • Render Problem
    Posted by Stevendukic on March 24, 2006 at 5:15 pm
    Got a big project with deadline. I am rendering a 45 second clip for each category in a nominations thing. It has the title appear, then go to the top right corner, then each picture appears, comes at camera, then goes away and goes to proper place. That’s it. I rendered the first one and it’s fine. I copied the motions to the next ones and did about 12 more. Come to find that every single one, except the first one, skips when it plays. Say your watching the title move. Instead of moving smoothly, it’s like it’s riding on a bumpy rocky road. The whole 45 second clip is like this. However, If I play the rendered version in Premiere Pro, it works perfectly fine. I have tried playing it in different media players to no avail. I even rendered it and played it on a different computer. My computer has never had this problem, I’ve rendered much larger projects without this happening. I have about 7 gigs of space left on my hdd, if that matters. PLEASE HELP A.S.A.P.
    Stevendukic replied 20 years, 6 months ago 2 Members · 3 Replies
  • Steven L. gotz
    March 24, 2006 at 10:12 pm
    What are you exporting in order to see it in Media Player?
  • Stevendukic
    March 24, 2006 at 10:31 pm
    I am exporting the small 45 second clip. Only one category worked in, the first one. After that, none of them work. I’m exporting it in DVI format, which I what I have to export. I also have another project that’s not so near completion. Today I exported a piece of it out, same settings and all, and it plays fine. I’m thinking it’s something to do with the fact that I copied the motion key frames from the first to the second one, from the second to the third, etc. Also, when you choose to export the timeline it should only export what is under the beige bar, or as I call it the render bar. when I chose to do a small piece from the other project that was successful, it only rendered what was under the render bar. When I exported all these skippy versions from the other project, it exported video that was not under the render bar. I do not know why, just giving a little info that could help. I appreciate your help.
  • Stevendukic
    March 26, 2006 at 2:09 pm
