Activity Forums Adobe After Effects Render Problem
  • Render Problem
    Posted by Ed Blackford on September 24, 2009 at 7:24 pm
    Hello all,
    I am trying to make a demo reel i did in the past larger in size. I am going from something pretty small to 1080×720. I did Layer>Transform>Fit to Comp. I go to the render que and try to make in an MPEG2. I get this error:
    After Effects: AEGP Plugin Median IO Plugin:
    There is a mismatch between Output Module settings and Transcode Settings. Please verify your settings and try again.
    Property Data Invalid!
    MediaIO2 error: 0x400e0004
    Frame Dimensions out of bounds
    (5027 :: 12)
    can someone tell me what this means please and how to fix it? thanks!
    Ed Blackford replied 16 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
