Activity Forums Apple Final Cut Pro Legacy Render problem
  • Posted by Colin Williams on January 26, 2006 at 6:03 pm
    I am running FCP 5 on osx 10.3.9, G5 2.5DP. I updated a project from the older version of FCP (being 4.5) and am attempting to render the timeline. No luck. The clips showing the red “needs render” lines are not rendering. I am clueless.
    I tried rendering every conceivable way, changing sequence settings, trashing the prefs file (several times), restarting the machine, and still the same thing. I even have another project that originated in version 5 that’s giving me the same issue.
    Why can’t it render?
    Any thoughts? Help!
    Colin Williams
    Colin Williams replied 20 years, 7 months ago 2 Members · 2 Replies
  • Peter
    January 26, 2006 at 7:44 pm
    Select the clips and hit Option+R – see if that does it. Next you could go to the pull down menus in the render area and try all the options. Doing Render > “What needs to render” usually does it too.
    Good luck.
  • Colin Williams
    January 27, 2006 at 5:16 pm
    Thanks for the suggestion. But…no luck. I tried every render option there is. Nothing. It did render the ‘Full’ in the ‘render only’ drop-down menu but several clips still have the red line and will not render for some reason. When I select Command+R or Option+R it flashes the status bar as if it’s already rendered. But no change.
    Any other suggestions?
    Clueless. Still.
    Colin Williams
    http://www.pensivecrow.com
