Activity Forums Maxon Cinema 4D Render preview
  • Render preview
    Posted by Alan Lacey on July 9, 2005 at 6:59 am
    Is it possible to render frame numbers to previews somehow?
    Also how do I abort a preview render, some of these can be very prolonged.
    Thanks Alan
    Alan Lacey replied 21 years, 2 months ago 3 Members · 3 Replies
  • Brian Jones
    July 9, 2005 at 3:19 pm
    [alan lacey] “Is it possible to render frame numbers to previews somehow?”
    Check off Frame in the HUD settings and then set Render HUD in Render Settings/Options – or use Xpresso to send the frame number to a Text Spline (and obviously, put that in an Extrude or Loft).
    [alan lacey] “Also how do I abort a preview render, some of these can be very prolonged”
    Start another Preview (which will ask to stop the current one)
  • Richard Powell
    July 9, 2005 at 3:22 pm
    Frame numbers, yes with Xpresso. Wire a Time node’s ‘frame’ output to the ‘Text’ input of a text spline. Put this in an Extrude nurbs with zero ‘movement’ so that it’s caps only. Child that to your camera if your camera is moving. Probably also possible with the Heads-up Display.
    To cancel a preview, hit make preview again, then hit cancel. Give ‘make preview’ a keystroke (it’s command-r for me) and make your life easier.
  • Alan Lacey
    July 10, 2005 at 11:28 am
    Thanks guys
    Alan
