Activity › Forums › Adobe After Effects › Render / Preview while scrubbing?
  • Render / Preview while scrubbing?
    Posted by Alice Kirisame on September 14, 2009 at 1:31 am
    Hello and good day.
    I hope this isn’t too basic/stupid of a question… but I’ve looked around all sorts of forums and done quite a bit of googling and still couldn’t find an exact answer.
    In some of the tutorials, I noticed that some people’s video’s are RAM cached(? the green bar for previewing) when all they’re doing is just simply scrubbing through the timeline. It doesn’t seem like they’re hitting the spacebar or doing a RAM preview, they’re just scrubbing through and the green bar gets filled. Is this because the computers that they are working with are just 8 core monsters of a machine that just tears through anything they throw at it, or is it some sort of a setting or a plug in?
    I’ve found Girdiron’s rendering application but it doesn’t seem like the behavior of Nucleo or Culeo Pro.
    Does anyone know what’s going on here?
    Thanks for your time.
    Kevin Camp replied 17 years ago 3 Members · 2 Replies
  • Tielman Dewaele
    September 14, 2009 at 10:33 am
    Hey Alice,
    I think it is because they edit the tutorial. You don’t want to see a ram preview rendering do ya? So they cut it out.
    For better ram preview Nucleo is a good one.
    T
    MacPro Intel Quad Core 7G Ram
    MacBookPro Intel Duo Core 2G Ram
    Cs4 Production Premium
    Cinema4D
    Final Cut Studio 2
  • Kevin Camp
    September 14, 2009 at 2:24 pm
    also, if you disable opengl for previews and set ae to use adaptive resolution instead, as you drag the cti thru the timeline, if ae renders the frame, it will cache it as you drag.
    simple comps will probably render frames this way, more complex comps may only render frames if you hold the cti there for a bit…. it really comps down to how fast your system is and how complex the comp/effects are. having multiprocessing enabled and enough ram to feed the extra cores will help.
    when opengl is enabled for previews, the frames are not cached, and multiprocessing for previews is disabled.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
