Activity Forums Maxon Cinema 4D render plane as alpha and remove everything below
  • render plane as alpha and remove everything below
    Posted by Scott Green on January 15, 2010 at 11:41 am
    OK, so I have a plane object that acts as a floor. On that plane I have various objects coming out of grass that appear embedded into the plane. From the camera angle I’m using I can’t see anything that goes below the plane and that is how I want my image to render but with the plane object also transparent and everything below it.
    I used a composting tag on the plane, maybe I didn’t have the right settings but when I rendered it out everything that I didn’t want to see underneath the plane was visible.
    Does this make sense?
    I’ll try and clarify: I only want to see the objects that are sticking out from the flat floor plane, everything else, below the plane and in the background will be transparent when I open the image in photoshop. Can you help?
    I really do love good design – https://www.splurj.com
    Scott Green replied 16 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
