Activity › Forums › VEGAS Pro › Render output is bad…using Camtasia…HELP
  • Render output is bad…using Camtasia…HELP
    Posted by Troy Thigpen on November 17, 2008 at 4:06 pm
    I had a previous thread about using Camtasia and the output being very bad. That thread is now buried and I am not getting any replies.
    This project I am doing is a software demo for a local company. They have captured their demo using Camtasia. They wanted a WMV file for the end result, but I am having huge difficulties in getting a good looking file. So now I am trying a Mpg2 file for a DVD.
    The camtasia project was recorded at 1024×768 AVI.
    I was told to pan and zoom for better results. Here is a screen shot of the MPEG2 file (played in Media Player):
    https://img234.imageshack.us/img234/8462/screenshotrc5.png
    You can see how bad this looks. This was done with the NTSC DVD template…720/480…29.970fps…VBR.
    Even not zoomed in, it does not look good…but even worse with the zoom.
    I need this project done by tomorrow and am freaking out. I don’t know what to do…I am about to have a nervous breakdown. I do not want to lose this business. I value your input…please help.
    John Rofrano replied 17 years, 10 months ago 3 Members · 4 Replies
  • Enrique Orozco
    November 17, 2008 at 4:21 pm
    ..your screenshot certainly doesn’t look very well … does the captured AVI looks good in media player ?… is it good playing in the Vegas timeline (without render) ??? … really is not that complicated:
    1- capture with a good selection window (size mentioned seems OK) and make AVI in Camtasia.. avoid any edition or dimension changes there …
    2- ingest clip in Vegas and edit … make your pan & zooms …render to required output format..nothing special here….. I’ve made this before with very good results ….
    Good luck
    Enrique Orozco R.
    iDEA DigitalVideoStudio
  • John Rofrano
    November 17, 2008 at 4:34 pm
    Did you create a WMV file at 1024×768 resolution? That should look best. Start with a bitrate of 512K and increase it in 512 increments until it looks the way you want.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Troy Thigpen
    November 17, 2008 at 5:55 pm
    Setting the output resolution to 1024×768 did the trick!! I was using “original size” and it was outputting to a smaller format.
    It looks great now. I can finally breathe again….thanks for your help!!!!!!!
  • John Rofrano
    November 17, 2008 at 8:21 pm
    Great! Glad it worked out.
    ~jr
