Activity Forums Adobe After Effects Render out to 60i
  • Render out to 60i
    Posted by Richard Tsai on September 22, 2008 at 4:10 am
    Sorry for the simple question but I have a motion graphic to render out to broadcast at 60i – so in the output settings should I use 29.97 fps or 59.94 fps?
    Kevin Camp replied 17 years, 11 months ago 2 Members · 1 Reply
  • Kevin Camp
    September 22, 2008 at 5:48 pm
    in the output settings leave the frame rate alone and just set ae to render fields (upper or lower)….
    if you happen to be rendering 24p (23.976 fps) footage to fields it will add a pulldown and up the frame rate to 29.97fps on it’s own, you shouldn’t need to change it manually.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
