Activity Forums Adobe After Effects Render out RGB and alpha using HDV 1080i60 codec?
  • Render out RGB and alpha using HDV 1080i60 codec?
    Posted by Rob Sankey on August 2, 2005 at 2:41 pm
    I’m trying to export a lower third with an alpha but the alpha option is grayed out in the render settings. Any way to do this and maintain my composition size, which is 1280×720?
    Thanks in advance,
    RS
    Rob Sankey replied 21 years, 1 month ago 2 Members · 2 Replies
  • Chris Smith
    August 2, 2005 at 2:43 pm
    HDV isn’t going to support an aplha I’m afraid. You’ll have to use a codec that does and just set it to the same resolution that your HDV project is in.
    Some codecs that support alpha are: Quicktime|Animation codec (very popular), PNG, TIFF, TGA, IFF.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Rob Sankey
    August 2, 2005 at 2:47 pm
    Thanks. I’ll give it a try.
    RS
