Activity Forums Adobe After Effects Render offset and 3d objects!?!?!?
  • Render offset and 3d objects!?!?!?
    Posted by Tyler Paul on July 15, 2007 at 12:58 pm
    I’ve been using the techniques from the projection tutorial from videocopilot. The ram preview looks amazing but when I go to render it looks like either the light and projection layer Or my white solids Or both become offset and the projection doesn’t match the layers.
    I have searched the archive didn’t come up with much. I have checked to make sure all my effects are in use and deleted the ones that weren’t. I’m currently just exporting instead of using the render queue because people have reported that with render errors this usually works. Still, I shouldn’t have to do that.
    What would cause something like this and better yet how do I fix it?
    Tyler Paul replied 19 years, 2 months ago 2 Members · 4 Replies
  • Roland R. kahlenberg
    July 15, 2007 at 2:42 pm
    Did you set your Shadow Map as per the recipe?
    HTH
    Roland Kahlenberg
    https://www.broadcastGEMs.com
    https://www.myspace.com/rorkrgbspace
  • Tyler Paul
    July 16, 2007 at 12:12 am
    Your going to have to be more specific. It looks magnificent in the ram preview so I know I did everything right. Fortunately the export did work but I still need to fix this.
    July 17, 2007 at 6:32 pm
    Hi Tyler
    In cases where renders do not match RAM Previes, it is almost always a case of render settings. You may want to to post your AEP here or provide us with all of the Output and Render settings. You could also do a screen capture of the settings and a frame of te RAM Preview and one of the rendered movie.
    Cheers
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects project files
  • Tyler Paul
    July 18, 2007 at 2:53 pm
    sounds good. I’m tied up with other projects now but I’ll come back later for help on this
