Activity Forums Adobe After Effects Render Network Issue
  • Render Network Issue
    Posted by Chris Darlington on October 8, 2009 at 2:02 pm
    Hi
    I have one macpro and 2 Pc’s. My workflow is do the job on the mac. i then set up the render queue for MultiMachine Sequence. I go to collect files, selected comp, reduce project, change render output. My problem is under “enable “Watch Folder” render it says “1 single machine render item” and “0 multiple-machine render items.”
    I can’t figure it out why it says 0 multiple machine render. I have the watch folder set up on the pc’s. I collect files and save to appropriate folder and only one of the pc’s will start rendering. the other machines says something like “no renderable items found.” Can anybody explain why I can’t get both machines to render?
    Thanks.
    Chris Darlington replied 16 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
