Activity › Forums › Maxon Cinema 4D › Render multiple durations
  • Render multiple durations
    Posted by Peter Young on February 21, 2011 at 4:12 am
    Hi guys,
    Is there a way to render different durations for each camera in a multicam scene using the render queue?
    (ie cam1 frames 0-200, cam 2 frames 30-90, cam 3 frames 70-140)
    R12 broadcast
    Adam Trachtenberg replied 15 years, 7 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    February 21, 2011 at 3:08 pm
    Yes, you would use the stage object, which switches between cameras.
  • Peter Young
    February 22, 2011 at 2:14 am
    Are you sure this would work with overlapping durations. ie I want some of the same frames from different cameras?
  • Adam Trachtenberg
    February 22, 2011 at 2:42 pm
    Sorry, I didn’t notice that you had overlapping frames. In that case you would have to save out different versions of your scene — one for each camera you want to use — and also save/load render settings specicifying which frames you want to render. You can then load these into the render queue.
