Activity Forums Adobe Premiere Pro Render Looks fuzzy.. like time relapse
  • Render Looks fuzzy.. like time relapse
    Posted by Emmanuel Bakare on February 5, 2013 at 4:24 pm
    Hello,
    I am having problem with my render. after rendering, fast moving images looks fuzzy. It looks like images blending is applied to the video or a time relapse effect. Below are the list of things i have tried and didnt work
    1. I rendered the 5 mins video in h.264, mpeg2 format
    2. I removed the Magic Bullet looks effect i had on the video
    3. I rendered the video in the sequence
    4. I rendered differently with CPU and GPU.
    I use premiere pro CS5 with a Core i5, 16GB mem and an nvidia GTX 550 card.
    Ivan Myles replied 13 years, 7 months ago 2 Members · 1 Reply
  • Ivan Myles
    February 6, 2013 at 5:22 am
    First, check whether Frame Blending is turned on/off. Also, does source frame rate = sequence frame rate = exported frame rate?
    To determine whether the issue is with the encoder, effects, or other, try exporting a 2-3 second long section of the source file without any effects applied. Import the exported file and compare it to the source clip (a difference matte can be helpful). If everything looks OK, start applying effects to the source clip and exporting new versions as you go. Import the new clips and compare (stack the clips on top of each other in a sequence).
