Activity Forums Adobe Premiere Pro Render line stays yellow after rendering (CS5)
  • Render line stays yellow after rendering (CS5)
    Posted by Jeff Davis on November 29, 2010 at 5:14 am
    I’m running PP CS5 (v5.0.2) on Win7 x64 with an Nvidia Quadro 4000 (Mercury Playback certified). My whole sequence initially displays a yellow render line. If I render the work area (via the Enter key, with max. bit depth and render quality selected), it still displays yellow. I’m a noob, but shouldn’t it display green? My previous system didn’t support Mercury, so the render line displayed red until I rendered a portion, which would then turn green. I have GPU enabled under Video Acceleration and Playback.
    Eric Johnson replied 15 years, 9 months ago 3 Members · 3 Replies
  • Greg Brand
    November 29, 2010 at 9:32 am
    You need to select “Render entire work area” – under sequence
    I have made a shortcut key to it with “cmd+Enter”
    that can be done under Edit/keyboard customization
    hope that helps.
    https://gregbrand.co.uk
  • Jeff Davis
    November 29, 2010 at 5:59 pm
    Aah, that’s exactly it. I was misinterpreting “entire work area” as “entire sequence” and avoiding it.
    As an aside, the documentation’s a little sketchy on this point, but my impression is that Premiere (via Mercury) only uses (approved) graphics cards for rendering previews, not for exporting/final renders. If that’s true, is there any net gain by rendering previews (accelerated by the graphics card) of the entire project before exporting, and then using those previews during the export, which are supposed to speed things up?
  • Eric Johnson
    December 15, 2010 at 8:15 pm
    I’m pretty sure the yellow line means premiere is very sure it can play it back in real time, therefore rendering it to a file is unnecessary. As to your second question i’m sure that would speed things up but you might take a hit in quality.
