Activity Forums Adobe After Effects Render Layers Script
  • Render Layers Script
    Posted by Josh Hamilton on September 13, 2012 at 8:54 pm
    I’ve been searching for prior posts on this so if anyone knows where to point me I can check that out too. Essentially I’m importing an XML to AE from FCP to key some interviews in keylight, after the keys are complete I attempted to run the Render Layers script to output the keyed layers as individual clips to then reconform in FCP. While it works, it also renders out the black before and after each layer. Is there something I’m missing that could help just render out what i need without the black handles lasting the length of the comp?
    Thanks.
    Josh
    Josh Hamilton replied 14 years ago 44,160 Members · 1 Reply
  • Josh Hamilton
    September 13, 2012 at 9:05 pm
    Duh, right under my nose, select Layer In/Out Range as oppose to Work area in settings for those other boneheads like myself.
