Activity Forums Adobe After Effects Render layered photoshop sequence
  • Render layered photoshop sequence
    Posted by Neil Anderson on June 28, 2011 at 9:03 pm
    Is there any way to render a photoshop sequence with layers?
    I want to run a photoshop action on all the frames in a clip, but require a mask layer. Since AFAIK photoshop actions can’t grab the mask from another file (in an automated way) I need to have the mask for each frame available in the same PSD file on a different layer.
    The filmstrip format would also make this possible, but I can’t seem to find that in the output modules.
    Neil Anderson replied 15 years, 1 month ago 2 Members · 2 Replies
  • Walter Soyka
    June 29, 2011 at 1:24 am
    [Neil Anderson] “Is there any way to render a photoshop sequence with layers?”
    Not that I know of. This would be a great feature request [link], though.
    [Neil Anderson] “I want to run a photoshop action on all the frames in a clip, but require a mask layer. Since AFAIK photoshop actions can’t grab the mask from another file (in an automated way) I need to have the mask for each frame available in the same PSD file on a different layer.”
    Perhaps you can accomplish what you need with Photoshop Extended’s video layers [link]?
    [Neil Anderson] “The filmstrip format would also make this possible, but I can’t seem to find that in the output modules.”
    Filmstrip has been deprecated.
    Walter Soyka
  • Neil Anderson
    June 29, 2011 at 4:51 am
    Thanks. I did end up using photoshop’s video layers. I hadn’t realized you could import more than one of them into a document.
