Activity Forums VEGAS Pro Render Just the Center 640×360
  • Render Just the Center 640×360
    Posted by Derek Pankaew on December 12, 2012 at 11:08 pm
    Hey Everyone,
    Is there a way to render just the middle of a video? I have a 640×480 video, but I want to render just the center area, so it’ll come out to 640×360. In other words, I want to crop the top and the bottom, but not the sides.
    So far I’ve been rendering to a 640×360 file, then creating a 640×360 project and using Match Aspect in the crop box to get it to 640×360, then rendering it again. But it seems like I’d going through an extra rendering step that just shouldn’t be necessary.
    So … Is there a way to do this? To render just the central area without having to go through an intermediary render?
    Thanks everyone 🙂
    Steve Rhoden replied 13 years, 9 months ago 4 Members · 6 Replies
  • Steve Rhoden
    December 12, 2012 at 11:12 pm
    Its easier to simply do the cropping on the timeline before you render.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • Derek Pankaew
    December 12, 2012 at 11:17 pm
    But how? I can get it to cut out the top and bottom, but it automatically stretches the video to fit 640×480 again. Or it leaves a white space at the top or bottom.
    I want to render a video file whose size is ACTUALLY 640×360. Can that be done in using crop?
  • Matt Carlson
    December 13, 2012 at 3:54 am
    In order to get what you want two things must be done.
    1) The pan/crop size on all your events (hopefully this is not a highly split and edited video already) has to be 640×360.
    2) When you get to the render dialog you must choose custom frame size in the frame size drop down and enter 640×360.
    If you do #2 without doing #1 all the video information will be squished in to the new aspect ratio. If you do #1 without doing #2 it will look fine but you will not get what you want: a actual frame size of x360. It will be a 640×480 video with borders baked in.
  • Aleksey Tarasov
    December 13, 2012 at 4:39 am
    • Set your project frame size to 640×360.
    • Open Pan/Crop window, right click and select Match Output Aspect.
    • Render with 640×360 template.
    Vegasaur.com – Plugins for Sony Vegas Pro
  • Derek Pankaew
    December 13, 2012 at 6:39 am
    Aha! Got it, thanks 🙂
  • Steve Rhoden
    December 13, 2012 at 10:51 am
    Ooohh, i just got back to this post,
    thanks guys for helping out Derek (smile).
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
