Activity Forums Apple Final Cut Pro Legacy Render issues with
  • Render issues with
    Posted by Maurice Paramore on January 20, 2012 at 7:10 pm
    Hello,
    I am working with Canon Dslr footage Apple pro res 1920X 1080 in final cut pro
    When I apply my magic bullet looks effect, this message comes up when I try to render it….
    “The effect “looks” have failed to render: Your hardware cannot render at the requested size and depth”
    I’m not sure what this means or if I need to upgrade to something? Please if you know the problem let me know
    I have an apple macbook pro… 2.4 Ghz Intel Core i5…Memory4GB 1067 MHz DDR3
    Intel HD Graphics
    Type: GPU
    Bus: Built-In
    VRAM (Total): 288 MB
    Ewald Vorster replied 14 years, 3 months ago 4 Members · 4 Replies
  • Chris Tompkins
    January 20, 2012 at 8:15 pm
    Check you magic bullet settings, reduce the color bit depth if you can.
    I have not used it.
    Chris Tompkins
    Video Atlanta LLC
  • Maurice Paramore
    January 20, 2012 at 11:01 pm
    Thank you for responding. I Can’t change any of that with magic bullet. Is there any settings on Final cut maybe?
    When I drop the video down to 720p it allows me to render it, but at 1080 it dosen’t
  • Rafael Amador
    January 23, 2012 at 9:46 am
    [Maurice paramore] “”The effect “looks” have failed to render: Your hardware cannot render at the requested size and depth””
    Your GPU is not enough to render the effect at that size.
    [Maurice paramore] “When I drop the video down to 720p it allows me to render it, but at 1080 it dosen’t”
    Right that.
    rafael
    http://www.nagavideo.com
  • Ewald Vorster
    June 11, 2012 at 8:59 am
    I have the same rednder problem, but I have a Black magic Decklink HD extreme 3d card, But get the same render problem in FCP 7 when trying to render 1080 clips with MB Looks.
    Im running 2×2.66 GHz-6 Core processor
    16 GB Ram
    Grapics is ATi Radeon HD 5770… is this not good enough?
    When i downres to 1440 is works but yea.. but not what I want to export.
