Activity › Forums › Apple Final Cut Pro Legacy › Render Issues in FCP 5.1.1 with DVCPRO HD – Fix?
  • Render Issues in FCP 5.1.1 with DVCPRO HD – Fix?
    Posted by Jt on June 2, 2006 at 2:50 pm
    Hi, I’m working with 720 24p HD footage, mostly from P2, and the HVX200.
    Here’s my problem: If something plays with real-time, everything plays well, and looks good. As soon as I render it, the first and last frames of a transition will have a skip in it, as if the render timebase were different; and the interviews that I render end up having the audio out of sync. So, what’s the deal? It was shot as 720p 24N, and I’m using the Sequence Preset DVCPRO HD 720p24… wouldn’t this be correct?
    So, either I’ve got a Sequence Preset set incorrectly, or, FCP 5.1.1 is giving me a hard time. Whatever the case, anyone know the answer?
    Jt replied 20 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
